many to one notification
I have already left a comment in idea exchange, as I thought there is no NI VI for this case.
I am looking for a VI which can handle many-to-one "notification" so that one VI has to wait until several other VIs meet a certain point and continue.
Comments welcome.
Sia
Message 1 of 16
(3,378 Views)
Hi Siamak,
see the Rendevouz. This do what you have described.
Mike
Message Edited by MikeS81 on 08-20-2009 11:02 PM
Message 2 of 16
(3,373 Views)
You mean sort of like the way it's done in the "Wait for All Notifications Demo" example VI?
Message 3 of 16
(3,372 Views)
Wait for All Notifications Demo.VI is the true example of the One-to-one nature of the Notifier. In this example, we see an array of notifiers being fired for each other on a one-to-one basis.
Although the many-to-one mechanism can be done using notifiers, we don't see unique VIs responsible for this strategy.
Sia
Message Edited by Siamak on 08-24-2009 06:27 AM
Message 4 of 16
(3,326 Views)
Rendezvous do not perform what I want of course. If you use them in different VIs, when reaching the point, they all WAIT for each other, so it is many-to-many so to say.
a many-to-one strategy can look like one VI when reaching a point, waiting for several others. Those others, when reaching the "notification" point fire some flag and continue. When all have fired the flag, the waiting VI can carry on.
Sia
Message 5 of 16
(3,324 Views)
Hi Sia,
you can also use a normal queue or notifier.
See the attached example.
Mike
Message 6 of 16
(3,322 Views)
Sure, but this solution is both resource and design space hungry.
Sia
Message 7 of 16
(3,287 Views)
Sia
Sia,
what is your solution?
Mike
Message 8 of 16
(3,262 Views)
I don't see that Mike's solution is resource hungry at all.
And for designe space, of course you would make it a sub Vi...
One flaw is: If a sender sends more than once, it will let the receiver run although not all senders have send their notification yet.
Here one more idea based on queues:
For each sender there is a seperate queue of size one (this way, it will send no more than 2 times before the receiver finished). The receiver has n dequeue primitives (one for each queue). Could be inside a for loop as well.
Felix
Message 9 of 16
(3,244 Views)
Hi Felix,
another solution would be that each sender send's an ID which will be checked against a buffer.
Mike
Message 10 of 16
(3,242 Views)
