maximum number of rows in a table
What is the maximum possible number of rows in a table. What happens when that number is exceeded?
(2,918 Views)
The short answer is the amount of memory you have available. HOwever, using REALLY large tables can be very slow. You can help performance if you preallocate the array (a table is really just a 2D array) and use replace array subset to update it.
When faced with these types of issues you really need to ask yourself whether or not you need all of the data in memory at the same time or can you store it and work with it in chunks.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(2,898 Views)
2,147,483,647
If you want to use any of the array functions that take an 32I as input to index an element of your array.
Omar
(2,886 Views)
Omar and Mark are both correct.  If you are using a large table, for performance reasons, you should buffer it in your program as a 2D array (preallocated, of course), and only put in the table what is actually visible at that time.  Hide the table scrollbars and use external scrollbars to control it.  If you need more help, let us know.
(2,866 Views)
