09-02-2010 04:31 AM
Hi everybody,
I'm programing an application under LabView to visualize a control panel with a background image (metafile format).
I need to scroll and zoom with the mouse all elements of the control panel (metafile image included), like a pdf viewer.
I've got it, but I get a flickering effect when I scroll it. I have read the solution is using double buffering. Anyone knows how
can I do it, but using the Windows API (using the Call Library Function Node)?
Thanks.
09-02-2010 04:53 AM
When you Initailize a process again and again flickering will be there... you can post your code if its not a problem.....
09-03-2010 05:20 AM
no problem, (the vi is labview 2009 version)
Another question...
in the zoom case, I used invalidaterect and updatewindow for redraw metafile ,but it didn't work, now I use only invalidaterect and It works, I think it was because updatewindow calls WndProc and WndProc is defined by labview and wm_paint message didn't reach my wm_paint message case, there is any way to rewrite the WndProc call?
thanks for your reply.
