myRIO analog voltage reference
I am looking to aquire analog input from an LM35 sensor to myRIO 1900, as per the datasheet the analog input channels on the MXP B support a measurment range of 0-5 V with 12-bit ADC resolution.
the LM35 sensor outputs a voltage of 0-1V with 10mV per C
previously in PIC or other microcontrollers design a ADREF+ and ADREF- is present on the hardware to choose the conversion reference voltage
since there is no ADREF pins in myRIO is it possible to control the reference voltage of a given pin for NI MAX or from an IO property/method node?
I tried using the method node for the AI input on MXP B but it has no methods, the property node showed two options none of them can be changed to "write" so I can set up a conversion between 0-1V reference and utilize the 12-bit resolution effieciently
Thank you
(4,528 Views)
NI myRIO does not allow to change the range of analog input channels. For the MXP connectors' analog inputs it is fixed to be 0-5V. It does not have also control for reference voltage. So the LSB is fixed and is equal to 5/(2^12), which is ~1.2mV.
What accuracy do you need for your application? BTW the accuracy of LM35 is typically +/-0.2 °C according the datasheet.
Arev
CTO | RAFA Solutions
Certified-LabVIEW-Embedded-Systems-Developer_rgb.jpgCertified-LabVIEW-Architect_rgb.jpg
(4,513 Views)
Use an op-amp to amplify your signal to the 0-5V range.
GCentral
(4,492 Views)
Hello and thank you
I was just curious about the availabilty of such option to change and control the REF voltages I am only using the LM35 for testing purposes
Certified Labview Developer
(4,463 Views)
Thank you the reading is accurate enough on the 0-1V volts I just wanted an answer to be sure if I can control the REF or not
(4,460 Views)
