negative number in formula node
good day.
I am trying to find information on how to include a negative number in the formula node.
thank you
Message 1 of 8
(717 Views)
Put a negative sign before the number...
Message 2 of 8
(694 Views)
Click on the border of the formula node, then click the key on the keyboard just above the arrow keys that says "Delete".  Problem solved.  😂
aputman
Heads up! NI has moved LabVIEW to a mandatory SaaS subscription policy, along with a big price increase. Make your voice heard.
Message 3 of 8
(687 Views)
thank you I see in the example you provided that I was missing a space between the function and the minus sign.
Have a goo day
Message 4 of 8
(673 Views)
Have a goo day
I generally don't like goo days (too messy).
Message 5 of 8
(667 Views)
A space is not required.
aputman
Message 6 of 8
(661 Views)
As some have already hinted, maybe the real solution is not to use a formula node at all. There is really never a compelling reason for them.
Can you take a step back and explain what you are trying to do?
Message 7 of 8
(612 Views)
There are compelling reasons NOT to use them , though, like:
  • They are orders of magnitude slower than if you created the same code using native functions.
  • You have to worry about syntax (exactly like what the OP is having trouble with).
Of course, this post isn't aimed at educating you, Altenbach.  😉
Bill
CLD
(Mid-Level minion.)
Message 8 of 8
(592 Views)
