ni 4551
Hi all, I am Currenltly having NI 4551
i need to do a project in wavelet ,so i have installed labview version 13 with advanced signal processing toolkit.
Kindly tell me what are all the device drivers and DAQ card to install .
(3,016 Views)
Hi Kreaks
I understand you are using NI 4551, you can find the drivers for the same at the link below:
http://www.ni.com/download/ni-dsa-1.2/966/en/
If you elaborate the objectives of your project, I can suggest a suitable DAQ card depending on the signal you want to acquire and process.
For more information you can refer to an NI white paper, you will find at the following link: http://www.ni.com/white-paper/3018/en/
If you have any more queries, feel free to ask.
Regards
Rohit Joshi
(2,974 Views)
Accepted by topic author kreaks
first of all thank u for the reply.
I need to acquire the vibration signal and process using Wavelet.
I have currently installed NI DAQmx 9.3.5 and NI Device Drivers.
With the help of traditional DAQ i can able to test the card.The card is working ,
but the options for the card is not coming in the palette.
Kindly tell me what are all the proceedings for the options of the card to come in the palette
(2,957 Views)
You just need to install a version of DAQmx that is compatible with your version of LabVIEW. Version 14 was just released (along with LabVIEW 2014).
(2,954 Views)
Hi Kreaks
You can find the DAQmx version compatible with the version of LabVIEW you are using at the following link :
http://digital.ni.com/public.nsf/allkb/B0D5630C0A50D5C6862578E800459248. You can find the DAQmx drivers version you need by a simple google search.
Could you please specify which DAQ card you are using to acquire the signal?
Regards
Rohit Joshi
(2,938 Views)
i am using NI4551 DAQ CARD
(2,838 Views)
