ni845x.llb version 21.3 contains broken VIs when opened using LabVIEW 2021
I am trying to open, alter, and re-build a LV project that was built by a previous engineer using LV2021. When I first opened the main VI, it came up with errors because it could not find the ni845x-related VIs contained within ni845x.llb. So, I downloaded ni845x drivers version 21.3 from the following link: NI-845x Driver Software Download - NI
After downloading these, LV did not come up with those same errors because the VIs in question could be located. However, the main VI was broken still. When I looked at the errors (I also attached an image: "Error_List"), it shows all of (or, at least, a lot of) the VIs contained in the downloaded library are broken. I also attached an image of an example VI which shows up as broken due to mismatched data types ("Example_Broken_VI"). I haven't touched the VIs at all after downloading. Am I possibly downloading the wrong version of these drivers? I only saw version 21.3 as an option for LV2021.
(751 Views)
Accepted by topic author livdre40
To anyone who has the same issue, I was able to resolve this by downloading the 2022 Q3 version of the ni845x drivers from the link in the original post.
(715 Views)
