nimdbgp.dll not found
I'm using LabVIEW 7.1
When using any daqmx vi's I get the following message:
this application has failed to start because nimdbgp.dll was not found.
I've tried uninstalling/reinstalling labview, daqmx, and traditional ni-daq without any success...keep getting the same error.
Can anyone tell me how to repair this?
Thanks.
Message Edited by dkotlow2 on 10-23-2006 10:07 AM
(2,874 Views)
I've never seen this error before. Which operating system are you using? Which version of DAQmx? (You can find this from within Measurement and Automation Explorer, under Software).
My recommendation would be to upgrade your DAQmx driver. Try using the latest driver that will work on your system. You can download that driver on our website. Let me know the results.
Garrett H
(2,858 Views)
Operating System: Windows XP Pro
Daqmx version: 7.2
LabVIEW version: 7.1
What Daqmx Driver version is compatible with LabVIEW 7.1 ?
(2,848 Views)
You can use the the newest version (NI-DAQmx 8.3) with LabVIEW 7.1.
Garrett H
(2,843 Views)
Ok...thanks.
Dominik
(2,838 Views)
