old application reports "The VI is not executable. The full development version of LabVIEW is required to fix the errors"
Something to do with MS Silverlight?
CLD; LabVIEW since 8.0, Currently have LabVIEW 2015 SP1, 2018SP1 & 2020 installed
Message 11 of 20
(1,016 Views)
@dkfire wrote:
@KaareBach wrote:
@PalanivelThiruvenkadam wrote:
Is there any addon Toolkits used in the application development?
What kind of application is that basically (What it does)?
No Toolkits used.
And no additional installers.
The application is a simple tool used to keep track on how we use hour time on different development projects.
So it is not a "normal" LabVIEW program: No external I/O boards etc. is used. It is only a user interface.
So how do you save the time?
Database ? Excel ? File ?
Everything is saved in plain text/csv files.
Message 12 of 20
(1,002 Views)
Hmmm, I have asolutely no idea 🙂
I use Silverlight controls in the application, but I have no idea if this could be a problem.
The other user, using my application has also installed Visio recently, but they have not seen this problem.
If it is Viso directly causing this problem is not for sure. But it happened just after installing it, and he is quite sure he did not do any other installations or updates.
br
Kaare
Message 13 of 20
(1,004 Views)
First thing to try is removing Visio.
But to continue the speculations for fun...
Are any TCP/IP functions used that require a port that Visio may have stepped on?
Ben
Message 14 of 20
(999 Views)
Ben
Yes he should try to remove Visio again. If it cleans up everything is not sure, be we will see what happens.
No TCP/IP used.
Message 15 of 20
(994 Views)
Windows System log may also have a clue.
Ben
Message 16 of 20
(988 Views)
(posting by phone, might have missed some answers)
Do all computers run the same Windows version?
Have you reinstalled/repaired the run time
engine? The application?
Does the app access any hardwired relative or absolute paths?
Did you check the HD for errors?
Does this computer run any unusual AV or other security software?
Does the user have the same privileges as on the working machines?
Message 17 of 20
(983 Views)
I think you mean Silver controls. Never heard of Silverlight controls. Silverlight should not be used without your knowledge (, but how knows).
Silver controls should not be a problem.
Message 18 of 20
(963 Views)
But maybe Windows did?
Message 19 of 20
(962 Views)
I was asking the question because I had an instance where I wasn't aware I needed Silverlight installed on a machine, but I had to include it in the installer as it is not a default part of Win 10. (but maybe it was NI MAX needing Silverlight and I barking up the wrong tree?)
Message 20 of 20
(951 Views)
