part of labview block diagram is unreachable.
In the attached file the green and orange wires(see arrows) go off the screen and can't be reached. Clean up of the wires doesn't work.
Message 1 of 8
(693 Views)
Hi Dennis,
This is the typical "block diagram is (way) too big" error…
Solution: get an older revision of your VI from your source code control repository, that doesn't show this behaviour!
Which numbers do you get in the Tools->Profile->VIMetrics for block diagram width/height?
Message 2 of 8
(690 Views)
See also
For clarity, please show an image of the diagram window, including the scrollbars.
Message 3 of 8
(631 Views)
Message 4 of 8
(567 Views)
@Dennis1956 wrote:
We already fully identified the problem!
It is not clear at all why you keep attaching new images without comment. Did you follow my link?
(Yes, I asked to show the diagram with the scrollbars, but we still can't see them!)
(Also, next time please consider embedding the images in the post instead of attaching as files).
Message 5 of 8
(549 Views)
Hi Christian,
There is a (horizontal) scrollbar visible at the lower border…
(On Win11 they tend to be pretty thin.)
On our conclusions stay valid: the block diagram seems to be VERY wide when the horizontal scrollbar is quite short...
Message 6 of 8
(527 Views)
@GerdW wrote:
There is a (horizontal) scrollbar visible at the lower border….
Yes, a scrollbar is not scrollbars. 😄
(All my LabVIEW is still on Windows 10, so I would not know how the scrollbars differ in W11 ....)
Message 7 of 8
(498 Views)
I'm fairly sure that if we open Navigation window (Ctrl+Shift+N) we'll see the problem.
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 8
(477 Views)
