please help me find the error in the annex VI,access
Hello, everyone, this is a program about ACCESS, please help me find the error in the annex VI, why do I always run time error. Thank you very much.
(2,228 Views)
Can't help unless you tell us what the error is. We are not mind readers.
Why are you performing a SELECT statement to get a recordset in order to perform an AddNew? Why don't you just use an INSERT command?
Your VI assumes the table doesn't exist in the database. What if it does?
(2,214 Views)
Thank you for your reply, I have an attachment process map, could you help me change it, I just want to put my number in the array can continue to update the database. And I want to create a table.
this is my msn :javaoc@hotmail.com
Waiting for your reply on line
谢谢你的回复,我的附件中有程序图,能不能帮我改一下,我只是希望,把我的数组中的数能够持续的更新在数据库中。并且创建一个我想要的表。
(2,212 Views)
