03-29-2013 09:59 AM
Bug?
I have a project in source control (Microsoft visual source safe), it is checked out using labview. But it affects only lvproj file, not aliases and lvlps files, they are still read only. So LabVIEW can not save properties that are kept in that files, like project window size. It will be a problem in projects with network targets: labview will not save their IPs, you will not be able to connect on next launch.
May be these files should not be in the source control (hardware IPs, window size can be different for different PCs), but they should be checked out and saved if they are.
03-29-2013 10:36 AM
Those two files are explicitly designed not to be put into SCC, as the LV help explains. I don't have experience with working with SCC from inside LV, but I'm assuming it has specific code to ignore them.
