putting the part of the code on the block diagram in "comments" like we do in C
Hi
Like in C, if I dont want the compiler to see few lines of code I just // or /* them. Is there a way to do same thing for a loop on a block diagram in Labview.
Kind Regards
Austin
(2,122 Views)
Structures Palette -> Diagram Disable Structure my be helpful for you.
Andrey.
(2,118 Views)
Also note that the CONDITIONAL DISABLE structure will let you include/exclude things - I use it for debugging code.  It's like:
#ifdef Debugging
    printf("Pressure is %0.1f, temp is %0.1f", P, T);
#end if
You define the symbols on the PROPERTIES page of the target, in the CONDITIONAL DISABLE SYMBOLS section.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
(2,111 Views)
