queue can not popup dialog program or VI
hello everybody,
          I program this , push "E" key, but not see popup  VI or dialog program. Who can help me to analyse and solute it ? thank you .....
Message 1 of 8
(3,130 Views)
What's in your 0 case? Can you post the vi?
LabVIEW 2012
Message 2 of 8
(3,127 Views)
What is this VI supposed to do?  If you never put anything into the queue, then you'll never be able to get anything out of it, and I don't see an enqueue anywhere (although with a named queue you could have one somewhere else that you're not showing us).
Message 3 of 8
(3,113 Views)
He is enqueueing a '0' just after obtaining the queue. But we need to see what is in that case or better yet the whole vi and the subvi that is shown in the selected case.
LabVIEW 2012
Message 4 of 8
(3,098 Views)
    now, give the queue "0", sub vi only has one while loop, not any thing.
Message 5 of 8
(3,075 Views)
my mind is when I push "E","F","G","0" key can open their sub vi, but debug only can see sub vi is running, however , can not see dialog box, why?
Message 6 of 8
(3,067 Views)
Accepted by topic author Billy.Deng
Which dialog box?  As previously suggested, it would help if you attach your VIs.  Without that we have no idea what you're trying to do.
Is your subVI a dialog box?  You may need to open VI Properties, go to the Window Appearance page, click Customize, and set the option for "Show Front Panel when Called."
Message 7 of 8
(3,054 Views)
thank you so much, i forgot to set up vi per, yes it is that.when i adjust it can show sub vi running.
Message 8 of 8
(3,028 Views)
