"Add Case For Every Value" option does not exist when I right Click a case structure.
Has anyone else seen this problem? I am running LV 2009. Wiring a Ring or Enumerated to a new case structure does not automatically create matching cases and the "Add Case for Every Value" option does not exist in the pull down menu when the case structure is right clicked. Could this be a bug?
Message 1 of 8
(7,214 Views)
Wiring a ring is not supposed to create matching values to the strings and it is not supposed to have the option 'Add Case for Every Value'. An enum does have this option and it works for me in 2009. If it's not for you, post a VI that reproduces the behavior.
Message 2 of 8
(7,206 Views)
Adding to Dennis (Knight of the Lightning Fingers)...
Check all of the source tht feed the selector to enusre you don't have two different enums or a ring in the mix anywhere.
Anther quick check is to show the help window (ctrl-h) and use the wire tool to float over the wires to ensure the wire is actually an enum.
Ben
Message 3 of 8
(7,203 Views)
To respond to the eventual question of "why not?" that may be asked: Good thing, too, since with the default data type of U16 for a ring that would be a whole lotta (65,535) cases that would be "conveniently" automatically added.
Message 4 of 8
(7,186 Views)
I have had this problem while working the Simple State Machine - Traffic Light.
When you open type def. be sure to right click the enum you are saving and "edit items..." This is where you can "Insert" the cases you want. Every word case will line up with a number ex:0,1,2,3,etc. Once you add all the cases, save the enum and close it, then the case structure should have the option to "Add Case For Every Value."
If the case structure does not have the option, you will still be able to add case before/after and type in the case you want without it showing up red.
I hope this helps!
Message 5 of 8
(5,659 Views)
I hope this helps!
Sounds like you either do not have a type def or have one or more constant wired that is NOT the correct type def.
Ben
Message 6 of 8
(5,645 Views)
I am so glad we are still trying to solve this problem after 8 years!!!
GCentral
Message 7 of 8
(5,638 Views)
I think my record was responding to a post that was about ten years old.  Yikes.
Bill
CLD
(Mid-Level minion.)
Message 8 of 8
(5,616 Views)
