reading of tdms file
Hello everybody,
I want to filter a previously saved TDMS file. For this, first I import it. But the problem is it reads the TDMS file till 0,06 seconds. I tried several ways to solve it but I couldn't succeed. Could anyone help me please?
You can find my programme as attached to this E-mail.
Best Regards
(2,111 Views)
Hi Zubrettin,
I would highly recommend you to use the low level VIs. As far as I understood you question you want to extract special informationen from the TDMS file. With the low level VIs you can directly search for the data which is interessting for you.
Please check out the example I added here. Its pretty straigth forward and should explain how it works.
Byebye,
RMathews
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
(2,094 Views)
