06-24-2013 04:17 AM
I am updating chart with every 500 ms but unable to display my pc's time to its x axis please help
06-24-2013 04:34 AM - edited 06-24-2013 04:35 AM
ONe solution, but maybe not the best 😉
I have in mind that the chart can keep the timestamp of single values depending on the properties set....
06-24-2013 06:10 AM
No its not working i wired the 2 d array to the chart and took its property node for multiplier and offset and insterted it in state machine architecture the delay between the two cases toggle is 500 ms and chat display settings its not updating. if i use xy graph and attach the timestamp to the x axis will it work.
06-24-2013 06:59 AM - edited 06-24-2013 07:00 AM
My example is intented to work arbitary (software) timed.
If you stop it and re run it some seconds later the chart timeline will still be correct 🙂 while still showing the old data.
Using XY graph with a buffer will do the same.
