09-28-2011 10:54 AM
Is there anyway to get the new silver controls for previous versions of LabVIEW?
Solved! Go to Solution.
09-28-2011 11:00 AM
I haven't tried this to confirm it, but I believe the answer is yes.
I believe the silver controls are just a directory full of control files under C:\Program Files\National Instruments\LabVIEW 2011\menus\Controls.
If you open them up in LV2011 and do a Save for Previous Version, you should be able to make them be able to open up in the older version of LabVIEW. The only other thing you might want to do is copy the menu files to the older version of LabVIEW so they show up in the palettes. C:\Program Files\National Instruments\LabVIEW 2011\menus\Controls\Silver
09-28-2011 11:12 AM
That is part of the problem, my funding for service contracts got cut back in the 8.6 days. So I am lucky to have a copy of 9, which was my last update. I guess if I wanted to try being sneeky I could download the evaluation version and see if I could borrow them that way. But it would be nice if NI made them available to other versions.
09-28-2011 12:04 PM
09-28-2011 12:09 PM
Bummer. But thanks for the info.
09-28-2011 12:43 PM
if you're looking for spiffy controls you could try the ones in the Communities: Group: UI Interest Group
