stop the program when object move out the front panel
First of all I want to say hello everyone.
I'm very begginer with the LabVIEW Program, so my question might be a little bit stupid or easy, but I'm trying do that a very long time and nothing's going good.
I mean I just want to do program which moved press button STOP by pressing button OK. This is what I do and everything is ok, button STOP moves (while I press button OK) and stops the program (while I press button STOP). But I also want to stop the program when button STOP move out from the front panel frame, even if it is a little bit (I show it on the screen number 1, when I want to stop). And I don't really know how to do that. I think I must to limit the front panel size (I can do that) for ezample 200x200 pxs and then make something like "stop when >200", I tried do that, but it doesn't work... what should I do? I should add the new structure, while for example? I also tried but even I have no idea in which place.
(3,052 Views)
Accepted by topic author ada_333
Hi ada,
welcome!
Your VI looks very complicated. Why not simplify it?
(3,034 Views)
Wow, you are right, now it looks very simple and logic, I am shocked how much simple it seems to be right now! Thanks a lot Smiley Happy
(3,026 Views)
also is it a programmatical way to read the front panel window size?
(2,755 Views)
Yes.
Use property nodes of the VI...
(2,748 Views)
But which one? Size of Front Panel Property in Metric is in bytes, I need in pixels. Actually I need to know current size of window and compare it to current position object. I was thinking about something like that, but in this case the button doesn't work
(2,739 Views)
