suggest a SCXI module which produces the analog output voltage of above 1kV?
I am expecting  to get high voltage of above 1kV from virtual instrumentation SCXI analog output module?
IS there a possibility to get such high voltage from SCXI module?suggest me the maximum range also..
(2,437 Views)
High voltage of 1KV cannot be produced from SCXI product family.  You might need to look into step up transformers setup for such high voltage requirement.
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
(2,433 Views)
Solutions I have seen were standard 10V ouputs feeding high voltage amplifier to drive piezo actuators ( amps were from PI (Physik Instrumente) in a seperate 19" housing).
Message Edited by Henrik Volkers on 09-07-2009 01:21 PM
Greetings from Germany
Henrik
LV since v3.1
(2,423 Views)
