I am trying to use a Tinerkit thermistor (T000200) along with a tinkerkit shield that is on an arduino Uno. I am trying to make a VI that displays the temperature in the various units (degC, degF & K). I get an output from the sensor of appox 3.4 and the I am using this value in the Steinhart-Hart Thermistor Equation. But, I think that I need to better determine the Thermistor’s total resistance. The values that I am using to calculate the resistance produce incorrect temperatures.
None of the documentation for this sensor has the particular values that I need for the formula. Does anyone know the information that I am missing (i.e. Paired Resistance, Vcc)?
Thank you,
