unable to clean up - nothing happens on ctrl-u or button press
Dear users,
I am unable to auto-clean up my code in the block diagram. I was in the process of reducing the code in the VI (shifting code to subVIs) and I realised later on, that I am not able to clean up.
It worked earlier. There is also an old-old version of the file, which I am able to clean up. This is only for reporting that there was a revision, for which the clean up worked. I would like to prevent reverting to it, and keep the new version.
I examined the following:
- no broken wire in comment structures (was an issue in LV pre-2013);
- I can clean up selections or selected wires;
What else should I check, please?
p.s. I am not able to upload the project/file for [due to complexity and confidentiality]
(3,106 Views)
I am able to copy all the code to a new VI and clean up that VI. I lost the revision number 😞 but I can live with that, if no other solution is possible.
(3,098 Views)
Which version of labVIEW are you using?
(3,083 Views)
LV 2013 SP1
(3,080 Views)
Accepted by topic author ghighuphu
I've found out the reason, for which I am unable to clean up. Grab the VIs below an try it yourself.
Spoiler
When the arrow of a floating comment points to a node (in my case, to the input node of a variable and the CASE structure), the Clean-up tool is puzzled.
(3,013 Views)
