usb 6008 et labview
Bonjour,
J'utilise la carte d'acquisition NI USB-6008. J'ai donc réalisé l'installation sur mon laptop et la carte d'acquisition est bien reconnue sur MAX. J'aimerais mantenant enregistrer les signaux directement sur LabVIEW mais elle n'est pas reconnue ni le driver. Pouuriez-vous m'aider à trouver une solution?
Merci beaucoup
Message 1 of 8
(3,368 Views)
Ayant du mal à comprendre votre problème, vous pouvez indiquer votre problème nouveau? Je vois la carte est reconnue par IMAX.
Wisdom is the principal thing; therefore get wisdom: and with all thy getting get understanding. Proverbs 4:7
Message 2 of 8
(3,347 Views)
It will be better in english:
I use the acquisition card NI USB-6008. So I made the installation on my laptop and the acquisition card is recognized in MAX. I would like now record signals directly on LabVIEW but the card is not recognized or the driver . Could you help me to find a solution?
Message 3 of 8
(3,337 Views)
Please be a little more specific with details. What version of LabVIEW and what version of DAQmx?
Message 4 of 8
(3,333 Views)
Ok, i'm currently using the evaluation version of LabVIEW 2015 and the NI DAQmx installed is NI DAQmx 9.7.5
Message 5 of 8
(3,327 Views)
That version of DAQmx is not supported with LabVIEW 2015. Download the latest.
Message 6 of 8
(3,312 Views)
Hello jugou,
Seems like you should upgrade to the latest NI DAQ for LabVIEW 2015,
NI Application Software Versions Supported by NI-DAQmx 9.7.5
NI LabVIEW NI LabVIEW 2010, 2011, 2012, and 2013
You can do this right from the NI website.
http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/catnav:du,n8:3478.41,ssnav:s...
Hope that works, God Bless!!!
Message 7 of 8
(3,309 Views)
Ohhh, I'll try that. I should have a good look before disturbing you.
Thank you
Message 8 of 8
(3,294 Views)
