web service installer error
I think I met a same or similar problem with LV2020 (64-bit). I was trying to deploy a web service with NI Web Server. The NI Web Server can be deployed correctly and is able to configure and run correctly. However, the deployment of an lvws file to ProgramData folder was timeout with postmultipart.vi. Rough feeling is the timeout still being 10 seconds.
However, with NI Web Server, my standalone build can work with its web service function successfully. So, I gave up to build an installer for it.
Message 31 of 33
(993 Views)
I was able to get a new build of the installer component with the timeout extended to 60 seconds.  This build is for LabVIEW 2020 SP1 32 bit.  NI support gave me permission to share this here.  If you need a different version, contact NI support and open a case.
I also requested they consider changing this tool so there is a config file with the timeout value available for user adjustment.
Hope this helps someone.
-John
Certified LabVIEW Architect
Message 32 of 33
(972 Views)
Hi, is there an updated build available for labview 2021, SP1, 64 bit?
Message 33 of 33
(745 Views)
