what do I've to change if I want to use my .vi with another DAQ?
I've done a labview project (.vi) adquiring data with an internal DAQ but now I need to work in another PC and I´m going to use a  DAQ-pendrive. What do I have to modify in my project?
Thanks for your time
(2,631 Views)
Without code I can't say exactly yes or no, but usually: nothing.
If old and new devices use DAQ driver and the same vi (read/write), then you need only correct name of device in code or configure task in MAX (depend on your method).
(2,618 Views)
Artem is correct, please specify what you mean also by pendrive, do you mean you have been using a PCI DAQ Card and are now using a USB DAQ Device? If so Artem is correct, for further understanding of DAQ and why Artem is correct, please find below a link attached which describes how DAQ operates and why it is not needed to modify code:
http://www.ni.com/white-paper/4752/en/
(2,604 Views)
