07-12-2011
01:44 PM
- last edited on
07-02-2024
02:21 PM
by
Content Cleaner
I am trying to save the data I collected from the measurement to the computer. I used the "data storage VIs" as introduced here, https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x3kACAQ&l=en-US. However, I find that if I follow the way in that article, the only data format I can choose to save my data is either tdms or tdm. And finally when I opened the tdms file after I stopped my program, I can only see some indexes of the data and cannot see any "real" data from the measurement. I am a little confused about this. What is the difference between *.tdms format and normal format we used like *.dat or *.txt, can *.tdms only save the properties of the data?
It's my first time using the data storage VIs to save the data, maybe this question is too naive 😞
Thanks!
07-12-2011
02:06 PM
- last edited on
07-02-2024
02:21 PM
by
Content Cleaner
Have you read the following?
https://www.ni.com/en/support/documentation/supplemental/06/the-ni-tdms-file-format.html
03-14-2012 06:10 AM
If your opening the file using Excel (you might need a file converter to do this), you might want to check the page tabs at the bottom- the index stuff normally comes up on the first tab and the actual data appears on the second one
