write real and imaginary parts in text file
Hi all
I am a rookie in Labview and I have a question.
I want write a .txt file with 3 columns where:
first column is the frequency
second column is the real part of FRF, and
third column is the imag. part of FRF
Can someone help me?
Carreira
(3,111 Views)
You want this:
Not this:
Depending on your version of LabVIEW, the 'write to spreadsheet file' should be polymorphic
Cory K
(3,102 Views)
You can also remove the 'open/create file' function.
The 'write to spreadsheet file' will create a new file if it does not already exist.
Cory K
(3,099 Views)
Thanks Cory K
I made the changes that you said, but the program still have error because "build array" output is a 2D array of 3 element cluster and the "write to spreadsheet file" input is a 2D array.
How can I make this conversion of data?
Im send my code for better understanding.
Carreira
(3,085 Views)
this may help:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(3,081 Views)
