x value of max y value from graph
Hey everyone,
I have one small issue (form me apparently is huge).
So, how can i get a value x of max y value from graph? I've attached two views. I knew how to take max from array but in my block digram for marque a graph i've used 'df' and 'f0' - how can i turne these on good value whith one will be good present as in the graph. Whot i am going to do is just take a x=f(ymax).
If you can help me, please?
Marek
Message 1 of 12
(4,973 Views)
Marek,
the function you are looking for is called Max&Min and can be found in the array palette.
hope this helps,
Norbert
Edit: You simply have to calculate the actual x-value regarding your scaling info: x-index * df + f0.
Message Edited by Norbert B on 05-03-2010 03:29 AM
Norbert
Expert: Geometry
Message 2 of 12
(4,971 Views)
Post some code for us to look at.
You can use the array max/min to find the max value of y. This will then also give you the index. You can use the index to then find the corrosponding value of x.
Message Edited by Lucither on 05-03-2010 03:27 AM
"Everything should be made as simple as possible but no simpler"
Message 3 of 12
(4,970 Views)
Thank for Your reply,
My issue is that, I don't knew how to take index value from two parameters df and f0?
Message 4 of 12
(4,960 Views)
hi lucither,
  Just check this attachment...
T hanks and regards,
srikrishnaNF
Srikrishna
Message 5 of 12
(4,958 Views)
Hi Gfds,
Your 2 paremeters df and f0 are not arrays, they are single double values?? You have made a cluster out of 2 double values, initialised an array with them but not set an array size, giving you an uninitialized array and then tried to index it?
If you can post some actual code rather then just a glimpse we may be able to see what you are trying to do and help. Is not all that clear at the moment.
Rgs,
Lucither
Message 6 of 12
(4,942 Views)
Accepted by topic author gfds
Hi Gfds,
Just realised what you are after:
I beleive this is what you are after.
Rgs,
Lucither
Message Edited by Lucither on 05-03-2010 04:12 AM
Message 7 of 12
(4,933 Views)
Here without Goldberg:
Norbert
Edit: Lucither bet me 😞
Message Edited by Norbert B on 05-03-2010 04:12 AM
Norbert
Expert: Geometry
Message 8 of 12
(4,931 Views)
Norbert,
If it makes you feel better i think i had a head start 🙂
Rgs,
Lucither
Message 9 of 12
(4,924 Views)
Now I am very happy. I've done as SrikrishnaNF showed in one version and second as Norbert B and Lucither showed.Two works perfectly.
Thank you SrikrishnaNF, Norbert and Lucither you answers were great, which such I wos awaiting.
I wish you nice work.
Best regards
Marek
Message 10 of 12
(4,905 Views)
