Tables are often used to display test results organized in columns, which means the user very often has to search a particular column for a specific value. At present the "search vertically" checkbox is not checked by default in Find in Table Cells dialog, which means the user has to explicitly select it otherwise the search could locate the wrong cell.
What I would like to have is the ability to programmatically set the relevant default options on the dialog before it is shown. With this I mean:
( Tested with CVI 2012SP1. Not yet installed 2013 )
