Starting from CVI2010, the User Interface Browser and the Attribute Browser are both located on the right of the UIR editor in the Workspace window.
I'd like to be able to hide these windows when required: when working on small screens like when you use a laptop these windows occupy a lot of space even if you reduce their size at the minimum.
In addition, the ability to choose which window to display on the bottom left could be a good option: up to version 2009 the bottom left side of the workspace window switched between the library tree (source editor) and the attribute browser (UIR editor).
Ideally, while in the UIR editor I would like to be able to:
