LabWindows/CVI Idea Exchange
mjl
Allowing install on Pre Windows 10
Status: New
I develop software for many older systems that can not be upgraded or are running windows embedded.  I just tried to create a new application and could not install it from my distribution.  I found out I had to go and edit the setup.ini.  NI Installer Requires Windows 10 64-Bit (Version 1507) or Newer.  I've been using CVI since the DOS days.  One of the advantages has always been that I could recompile and I generally didn't have to worry about Windows updates screwing up my software.  This change seems ridiculous all of a sudden.
1 Comment
RobertoBozzolo
Proven Zealot
Since you are a long time CVI user, you may have a licence that covers previous versions as well. If this is true, you can install an old version of CVI that matches target characteristics and recompile your project there.
Get in touch with your NI representative to check this possibility.
