I added the tab control into panel to my project. Overtime, I added 20 items into the single Tab Control. But since were so many items in the tab control, I decided to re-arrange items (indexes) in the tab control by either moving them left or right depending on the alphabetical order. But here is my problem.
Since I re-arranged the items (indexes), the indexes have all changed for all the items. Now I have to go everywhere the function GetPanelHandleFromTabPage is called and manually update the index numbers to match panel handles for the index. There are 20 different places where this could occur. The number of items (indexes) on the tab control could grow even more and may have to be re-arranged again in the future. Just a big pain.
Suggestion for improvement: Provide a another function that can obtain the index of the item on the tab control dynamically. This could be done by using the "Constant name:" issued in the edit tab panel of the edit tab control. So if the items (index) inside the tab control are re-arranged then the index value for that item is carried with the new index value.
Also the index would be included in the header file generated by the panel editor for CVI so that now the index value can be used thus eliminating the hard coded the index value.
