Hello NI world,
when modifying functions I typically encounter errors such as:
30240, 1 Redeclaration of 'xyz' previously declared at ab.c:1621.
when I forgot to adjust a parameter etc. It would be useful if I could use the right click popup menu of the build output window to jump to the first declaration in order to fix it. Right now, there is only the menu entry Goto Item
