A couple of minor things:
1. Change it so that if characters like 'µ' are used in the documentation tags, that CVI doesn't generate invalid XML comments files. Or if that is not possible warn the user if they use characters like 'µ' in the documentation tags.
2. Make it so that Insert Construct -> Function Documentation Tags (Ctrl-Shift-G) doesn't insert an HIPAR paramater for 'void' for functions that don't have parameters. Also make it so that it doesn't insert HIRET tags for functions that don't return anything.
