LabWindows/CVI Idea Exchange
Bertrand_ENAC
Graph improvements
Status: Completed
Introduced in LabWindows/CVI 2013
I have 2 suggestions for graph improvements.
1/ I suggested the first one a long time ago but it has never been implemeted so I try again trough this idea exchange board.
I would like to have the possibility to change the grid lines style to dash or dot. Today only solid is available.
I have written a routine to do it for printing graphs but as you can see it in the attachment it is not always working properly.
2/ It would be nice to have the possibility to set a percentage of transparency for the plots. In the example attached you can see if the green plot would have been behind the blue some parts would not have been visible. By setting the percentage of transparency of the blue one the green if behind the blue would become partly visible.
These 2 features are already available in the 3D graph so it would be nice to have them also on 2D plots.
Regards
Bertrand
4 Comments
vix
Great ideas!
Extremely simple, but with a large impact.
Kudos
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
gtoph
I'll just add one more to your list and that is to add scroll bars on the graph legend so we can see all the avaliable plots.
LuisG
NI Employee (retired)
Status changed to: Under Consideration
JonathanN
Status changed to: Completed
Jonathan N.
