Currently, when a CVI application is deployed on a PC with a DPI setting different than the development machine, the application will generally not look like how the programmer intended as the fonts get resized while the other UI elements do not, leading to overlapping text, awkwardly resized controls, etc. One way that DPI scaling could be implemented in CVI would be to use the same functionality as the 'Scale Contents on Resize' option for panels, where internally CVI could resize the panel and use this scaling to rescale all the UI elements (including fonts) on the panel to the appropiate size per the Windows DPI setting. This would make the panel look a lot closer to what the programmer intended and would generally make most applications usable with different DPI settings without any additional work from the programmer. Per my other suggestion, I would request that the programmer has the capability of disabling this functionality so they can handle DPI scaling themselves should they wish to do so.
Thanks.
