LabWindows/CVI Idea Exchange
Chupakabra
Implement Modbus RTU/TCP protocol support
Status: New
+ Implement Modbus RTU master/TCP client protocol support in CVI
4 Comments
gdargaud
There are two open-source modbus libraries available that compile fine with CVI. They both are incomplete in different ways but they work. Incidentally, both are named libmodbus.
CVI-User
If this might become reality please consider UDP, too.
/* Nothing past this point should fail if the code is working as intended */
ottifant
We have a Labwindows CVI Application realized with LabWindows V6.0. This application should communicate with a Matrikon server via Modbus TCP protocol.
Is it correct, that therefore we need to implement a Modbus RTU/TCP protocol support in the LabWindows application. We have the Matrikon Server and the
LabWindows application on the same PC. There should be no problem to communicate via Modbus /TCP on the same PC between the LabWindows application
and the Matrikon OPC server?
SASA1
please specify were to find theme
