LabWindows/CVI Idea Exchange
Miha_Vitorovic
Improve C preprocessor
Status: New
The C preprocessor in other compilers has seen some improvements over the years. Maybe you could freshen the CVI one up a little bit. With most modern C compilers there are some pretty advanced things that can be done in the preprocessor. But include those header files into a CVI project, and you start getting errors in the strangest places. And the cause of these isn't even some nasty trick, but pretty basic stuff for any other preprocessor.
2 Comments
LuisG
NI Employee (retired)
Hi Miha,
Could you post some examples of code that the CVI preprocessor does not handle?
Luis
Miha_Vitorovic
A bit of a background first: I was trying to make some DLL compile that uses a lot of Windows header files. On closer inspection it makes sense the do not work in CVI, since the macros actually expand to MS specific things. I just wish the error message would be clearer than " "crtdefs.h"(560,121)   syntax error; found ')' expecting ';'."
Sorry about the noise.
