What is differnce between the forum and the knowledge base ?
As far as I see the forum is where users ask questions and answers are provided, often by NI representatives.
The Knowledge base appears also to be where questions are aksed have solutions provided.
This means that I could search the knowledge base when the same question/solution is in the forum and vise-versa. Can these be in some way combined with a better search function .
It would also be useful to remember search location based on user login - The amount of times I end up with a solution using LabView (I do not use and hopefully never will use Labview).
