I've been looking around for a way to open the LabWindows/CVI print dialog box. It appears when you call the PrintCtrl function, does NOT appear in the PrintTextFile or PrintTextBuffer functions, and there is no function to open it directly; I need to print from a text buffer and would like to open it directly from a Print Setup menu function. The best recommendations that I have received are either use the Windows PrintDlg function, or to kludge the text into a hidden control and print the control. I highly recommend either adding it to all user interface library print functions or allow the user to call it directly.
