We use the our development and target installation PC's to support both new and legacy projects that were developed under earlier versions of IVI Compliance. As the only current way to change IVI versions is to uninstall and re-install, we are stuck using the earliest one as a common denominator. With hundreds of old projects to re-compile, frequent across-the-board updates are not possible. Newer versions of instrument drivers such as HSDIO are only compatible with later versions of IVI.
I would like to have a reasonably easy way to switch IVI versions, so we can support both old and new code from our development PCs. Even a batch file and some registry edit instructions would be better than the way it is now. However, that would limit its use in a secure environment where the users don't have general admin privileges.
From an NI business perspective, this may be blocking customers from purchasing upgrades or new NI products.
