The shortcut "Ctrl+Space" is for changing the input method in the some system.
Even we can change the shutcut, this function is so often to use.
The ideal is to make it like the way in some common source editor: when typing from any space position, the completion shows automatically.
This could be an option, to toggle on or off in Edit>> Auto Completion menu item .
