LabWindows/CVI Idea Exchange
Laser
Prompt Popup with initial value
Status: New
sometimes I use the built-in PromptPopup function, in order to get the user input. It is very comfortable having this feature, but I'd appreciate it more, if I could initialize the "Response Buffer" passing a not void string.
This means that if the string passed to Response Buffer is void, the function works exactly as today. Otherwise, if the string contains some value, the input field of the popup window will be initialized with that value.
Kind regards,
Sergio
