LabWindows/CVI Idea Exchange
Wolfgang
Provide enhanced Run»Break on»Library Errors
  • Right now, the Break on»Library Errors function break happens for all library errors. I would like to suggest a more granular setting, i.e. break on file I/O errors, math errors, etc.
  • An additional (and most relevant) feature I suggest is the option to allow to temporarily exclude certain errors; let's say I have a loop doing some calculations and these calculations result in an ERANGE error, then it would be useful to get notified by the debugger, but only once for this loop, not 500 times... Hence after a break on library error I would like to have the (right click) option 'exclude further breaks of this function'. This should be valid for the current execution and be automatically reset when the program is restarted.
  • Also, the menu command should provide the possibility to override all SetBreakOnLibraryError functions.
Many thanks!
1 Comment
LuisG
NI Employee (retired)
Status changed to: Under Consideration
