LabWindows/CVI Idea Exchange
Johannes_T
Swap Lines
Status: New
Summary:
Implement Swap Lines shortcut key (Alt+Up/Down).
Description:
Often, I need to swap two lines of code in my source file or maybe just move one or several lines up or down inside my code.
In order to do this, you normally have to do a cut and paste in order to move the lines.
Having a Swap Lines feature in the CVI source editor could significantly speed up this process, especially when you have to handle big chunks of code.
The Swap Lines mechanism could be triggered by the Alt+Up/Down.
This feature should also support multiple lines selections.
1 Comment
gdargaud
While we are at it, I really would  like Ctrl-delete to delete the word after the cursor, like in any other editor (try it in your firefox editing box as you reply to this!). I keep trying to use it in the CVI editor.
