LabWindows/CVI Idea Exchange
aplication_developper
add the 'view control callback' to menu items from uir editor
Status: New
saves alot of time for searching the CB manualy in huge projects
5 Comments
Wolfgang
Trusted Enthusiast
Could you be more specific in how this suggestion differs from the current possibility to "right click" a given menu item in the UI editor and choose View Menu Item Callback?
RobertoBozzolo
Proven Zealot
As you can see here, this feature was introduced in CVI 8.5. Could it be that aplication_developper is running a previous version?
mmeinders
I am running CVI2013 but I can't make it go to the callback function in the source code. When I Right Click on the menu item in UIR edit mode, and select 'edit' it opens up the menu bar panel for that item. How do I jump to the callback function?
Wolfgang
Trusted Enthusiast
Hi mmeinders,
above the 'Edit' item is the ' View Menu Item Callback' item Smiley Wink
My Idea was to add the same functionality also from the 'Edit menu Bar' panel
to save time in the process of closing this modal panel , go back to the uir editor, right click on the menu item , go to the source , and finally reopen the the  'Edit menu Bar' panel for further editing
