Might it be possible to implement some utility so that the debug_printf function could print to a window (or even the debug-output window in LabWindows/CVI) from a program that is NOT running under the debugger? I'm workng on a program that does some near-real-time data acquisition, and running it with the debugger from within LabWindows/CVI slows it down too much, to the point where it can't respond to the DAQmx notifications and the program crashes. Since I have a multi-core machine, I can, however, run it as a separate process at the same time as LabWindows/CVI.
