LabWindows/CVI
64-bit integers LabWindows CVI 8.0.0
I have send a response on this forum that CVI 7.0 supports 64-bit integers (by Mr. Matthews).
We run CVI 8.0.0 and the following code does not compile:
#define UInt64 unsigned long long
#define Int64 signed long long
UInt64 temp = 0;
Produces the error "Invalid use of 'long'."
Can I assume that this is not true and that CVI 8.0.0 and 7 do not support 64-bit integers?
Christopher Povey
Principle Test Systems Engineer for BAE Systems.
(3,889 Views)
Browser crashed.  Moderators please delete duplicate thread.
Christopher Povey
(3,885 Views)
The CVI help on Data Types shows both unsigned __int64 and __int64 available for 64 bit integer work. I have used them without difficulty from CVI 7.0 onwards, although some people have reported compiler issues with certain use cases - a search of the forum should soon find the related threads.
JR
(3,882 Views)
Hello Christopher,
The long long syntax was only introduced in version 8.5. In previous versions, you would have had to use__int64, as JR pointed out.The two types are equivalent.
Luis
(3,855 Views)
I have recoded the function to use __int64 and binned my Watcom C DLL that did the work before.  It compiles up okay, but I have not had chance to run it yet.
I have had a look through the forum on __int64 issues, and all my variables are non static so I should not get the GPE problem.
Thanks.
Christopher Povey
(3,845 Views)
