LabWindows/CVI
64bit integers support
Hi!
I have to link a .lib that use __int64 type (from Visual C++ 6 I suppose)
So just two questions:
1] Can CVI ver. 6.0 does support 64 bit integers?
2] It can exist a workaround to use 64 bit integers in CVI5.5 ?
Raffaele
(2,757 Views)
No, CVI does not support 64-bit integers... yet. Unfortunately, there is no workaround that you could use the call a function with a __int64 data type. You would have to go to VC++ or another compiler and build a wrapper DLL around the functions that uses 2 int32's or something similar.
Best Regards,
Chris Matthews
(2,757 Views)
