LabWindows/CVI
8.1 and 8.5 compatibility issues?
I am wondering what sort of compatibility issues may exist between CVI 8.1 and 8.5.  I am trying to run an exe built in 8.5 on a system that only has 8.1 installed.  The following message occurs at run-time, "The procedure entry point _UP_GetUDPAttribute could not be located in the dynamic link library cvirte.dll."  Afraid that this is a compatibility issue, but wanted to confirm.
-Joel
(3,312 Views)
This is probably due to a wrong Run-Time Engine installed in the target machine: the error you are reporting is related to UDP, which is a feature introduced in CVI starting from version 8.5, while your target machine has the 8.1 version installed. The runtime engine is usually backward compatible so you should be able to install 8.5 runtime in the target system and continue using 8.1 development environment without problems (if I understand correctly your assertion about your tharget machine).
(3,302 Views)
As Roberto says, you cannot use an older runtime engine with a newer CVI program.  The newer program is linked against a version of the runtime engine that has more entry points which it tries to load at startup.  An older runtime engine won't have these entry points.
However, an older program will run fine with a newer runtime engine without having to be recompiled.
Mert A.
(3,286 Views)
Thanks for the useful info.  It may be that I can have 8.5 installed on the target machine, so that will probably be the best way to go.
(3,265 Views)
